Switch connected to hub
Answered Question
Feb 25th, 2009
Hi all,
if switch port is connected to hub and we have 2 pc connected to hub.
if we do sh mac-address on switch with
MAc- address of each pc will it show same
port for 2 different mac address for pc?
also if user pn pc 1 is sending data to pc 2 how data will go directly via hub only or will it go to hub then to switch
and then to hub and users.
will cam table entries show both pc mac address or hub mac address on the incoming port?
many thanks
Correct Answer by Giuseppe Larosa about 7 years 11 months ago
Hello Mahesh,
the sh mac-address-table interf type x/y will show two entries
the switch knowing that both MAC addresses are out the same port will perform MAC address filtering and will not forward frames originated from PC1 and destinated to PC2 to other switch ports in the same Vlan.
For how the hub works each frame is sent out all other ports with the exclusion of the receiving port.
you will never see the hub mac address unless it has a management TCP/IP stack:
the hub is simply an electrical repeater that obliges to work in half duplex for what I write above: it replicates a frame out all other ports
Hope to help
Giuseppe
Correct Answer by Edison Ortiz about 7 years 11 months ago
Yes.
Data will remain in the hub.
Both PCs. Most Hubs have no intelligence (no MAC address).
__
Edison.
Correct Answer by Jon Marshall about 7 years 11 months ago
Mahesh
"will it show same
port for 2 different mac address for pc?"
Yes the switch port will show both PC mac-addresses.
A hub sends data out of all ports except the port the data came in on so if PC1 sends data to PC2 then the data will not have to go "via" the switch altho the switch port will also receive the traffic in addtion to PC2.
Jon
Overall Rating: 5 (3 ratings)
Correct Answer
Jon Marshall Wed, 02/25/2009 - 07:33
Mahesh
"will it show same
Jon
Correct Answer
Edison Ortiz Wed, 02/25/2009 - 07:34
Yes.
__
Edison.
Correct Answer
Giuseppe Larosa Wed, 02/25/2009 - 07:36
Hello Mahesh,
Hope to help
Giuseppe
mahesh18 Wed, 02/25/2009 - 07:57
Hi ,
Thanks all for great timely reply to answer my question
Many thanks
Mahesh
