need your kind help ?!
Feb 25th, 2009
hi there,,
I am a communication engineer i realy need you kind help?!!in my orgnaization around 160 employees and we are going to move to a new building & i am planning for ip telephony system please provide me what kind hardware & software i need to build my cisco ip telephony, i have tow cisco router 1700 & 1800 will this compatible for ip telephony ? plz help me with your kind advice ..
Thank you ..
Hythim Ali El Hadad Wed, 02/25/2009 - 08:33
Hi Khalil,
You will need to a have the following:
1- 3560-48-POE
this will be the access switches which will power your IP phones and connect your LAN,
You can connect then your PCs behind the IP phones which hace a port to the switch and another to the PC
Each switch is 48 port
So consider your needs.
2- Call manager
You can check on cisco which version will fit you needs
you can check this link
http://www.cisco.com/en/US/products/sw/voicesw/ps556/tsd_products_support_series_home.html
3- also it is better to have a 2821 router to act as your gateway
IT will support you having E1 to pstn and FXOs and FXSs and a unity express if needed
the ability to add PVDMs
It is the best one for this solution
For your 2-routers, please specify the exact models of them
Wish this be helpful :)
khalil-zadjali Fri, 02/27/2009 - 22:43
Thank you mr.haythem for your value information, but still some gaps need to be covered..i well expaline more :
i having my network LAN what extra devices i need to have ip telephony,my router 1700 series.if possible plz draw a diagram for devices that i need connected to each other..i realy Appreciated your kind help.
Thank you ,,,
Nicholas Matthews Wed, 02/25/2009 - 09:48
Hi Khalil,
You have three options for call control:
You could get a 3845 and support up to 250 users. The 1800 will not support anywhere near as many people as you need for CME. You could squeeze into a 3825 CME, as it supports up to 175 users.
You could get CUCMBE, this is CUCM/unity connection in one box.
You could buy a full CUCM cluster, along with Unity. (this is probably too large for 160 users)
For hardware you will need a voice gateway with a PRI. This means you will probably need at least 1-2 PVDM2-64 for DSPs, you may want a VIC-2FXO for 911 emergency access, and probably a VWIC-2MFT-T1 for a T1 access. You could put this into your 1800 or 1700 as long as they are a voice capable router (1861 and 1760-V).
You would need to look into something like a 2811 with a NME-CUE.
As well, you would need to get the IP phones, PoE capable switches, and the licensing for all the above.
I would contact a local sales contact, and they will be able to give you the full information on all of this.
