02-25-2009 10:18 AM
Can some one suggest which slot does DS3 card can be inserted in router 7206 series & can i get doc on the same.
thnks in adv.
--srini
03-03-2009 07:43 PM
You can place a port adapter (DS3) in any of the six slots (slot 1 through slot 6). Slot 0 is always reserved for the I/O controller.
http://www.cisco.com/en/US/docs/interfaces_modules/port_adapters/install_upgrade/serial/pa-t3+_serial_install_config/3505over.html
Log in to Community
