WallBoard
Jonathan Schulenberg Wed, 02/25/2009 - 18:50
  • Cisco Designated VIP,
    2017 IP Telephony
Not really. Agents can see calls waiting in the CSQs they are skilled in. Supervisors can obviously see status through CSD.
There are several third-party options:
-Inova Solutions
http://www.inovasolutions.com/call-center-reporting/products/index.htm
-Spectrum Corporation
http://www.specorp.com/
-IPCC Wallboard (Open Source)
http://sourceforge.net/projects/ipccwallboard/
-Business Communications By Design
https://www.bcbdsolutions.com/
iftikharsyed_2 Wed, 02/25/2009 - 23:14
You can use CRS scripts with CRS http subsystem to get the queue statistics displayed on a web page. CRS script uses "getReportingStatistic" to get information from IPCC.
Message if you need any further details.
HTH,
Iftikhar
iftikharsyed_2 Thu, 02/26/2009 - 21:12
I am not sure about your version of IPCC but we used queuestats.aef scrip from script repository http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_implementation_design_guides_list.html
its very simple all you need to do is
1. create a script and get the required values from queue (using getreportingstatistic)in variables.
2. Use http post to substitute these values in a predefined template.
3. use script in an application
4. make a http trigger and use the application with the trigger.
HTH,
Iftikhar
clachoi Thu, 02/26/2009 - 09:37
There is a wallboard db table that you can use (other 3rd party wallboard program uses that too)
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_4_0/maintenance/admin/crs401ag.pdf
page 434 of pdf shows how to turn it on.
and the release note shows how to setup access to that table
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_4_0/release/notes/4.0.5/crs405rn.pdf
page 47 of PDF
Here is the DB schema guide showing the wallboard table structure for use:
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_4_0/user/db_schema/crs401ds.pdf
page 56 of PDF, the table name is RtCSQsSummary
You can then build your own app accessing this information through ODBC
