Bandwidth Points - 7206VXR
Hi there
I get the following message in the output of show version:
PCI bus mb0_mb1 (Slots 0, 1, 3 and 5) has an aggregate of 600 bandwidth points.
Total of 200 bandwidth points have been used on PCI bus mbo_mb1.
PA's (PA-IO-2FE = 400) has/have over subscribed 200 bandwidth points in single
port configuration on PCI bus mbo_mb1.
PCI bus mb2 (Slots 2, 4, 6) has an aggregate of 600 bandwidth points.
Total of 0 bandwidth points have been used on PCI bus mb2.
PA's ( ) has/have over subscribed 0 bandwidth points in single port configuratio
n on PCI bus mb2.
I have a 7206VXR Router
with Cisco IOS Version c7200-ik9s-mz.123-9e.bin.
The mb0_mb1 PCI bus should take a total of 600 bandwidth points. The I/O
Controller C7200-I/O-2FE/E uses 400 bandwidth points. There are no other
PAs or SAs in the other slots. So I don't understand why does this message appears?
Thanks in advance.
irisrios
Level 6
Level 6
The output from "show version" does not take into account the actual port status, and only calculates based on the assumption if this is a supported configuration or not. This is given that we only use half the number of ports available.
