ASA5520 ACL ELEMENTS
Feb 25th, 2009
Hi, I have a doubt about same ACL's over ASA5520. Do you know where a can get same document or same datasheet that contains the maximum acl elements number that i can have on an ASA5520??.
Thanks a lot.
Regards.
Elias.
auraza Thu, 02/26/2009 - 13:09
  • Cisco Employee,
I believe it depends on the memory, as each ACE will take a certain amount of memory. Of course, you wouldn't want to have too many ACLs, as that could cause memory depletion.
