02-25-2009 11:48 AM - edited 03-04-2019 03:43 AM
How do you prevent the default route from being injected into EIGRP when you issue the redistribute static command under the eigrp process?
02-25-2009 11:53 AM
You can attach a route-map to the redistribute command denying the default route, let me know if you need an example config.
02-25-2009 11:56 AM
Yes please send that config!!!!! and thanks for the quick reply
02-25-2009 11:58 AM
Just in case
Router(config)#router eigrp 1
Router(config-router)#redistribute static route-map DENY-DEFAULT
ip access-list standard deny-default
deny 0.0.0.0
permit any
route-map DENY-DEFAULT permit 10
match ip address deny-default
statics
ip route 0.0.0.0 0.0.0.0 Null0
ip route 1.1.1.1 255.255.255.255 Null0
eigrp topoligy
Router#sh ip eigrp topology
IP-EIGRP Topology Table for AS(1)/ID(192.168.1.1)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - reply Status, s - sia Status
P 1.1.1.1/32, 1 successors, FD is 256
via Rstatic (256/0)
P 192.168.1.0/24, 1 successors, FD is 128256
via Connected, Loopback9
02-25-2009 12:44 PM
Adam thanks but I forgot to mention that the route was on an ASA, but I managed to figure out how to do it.
route outside 0.0.0.0 0.0.0.0
access-list eigrp_list standard permit 10.0.0.0 255.0.0.0
access-list eigrp_list standard permit 192.168.2.0 255.255.255.0
router eigrp 123
net 172.12.0.0
redistr static
distribute-list eigrp_list out
Thanks again for your help Adam and thanks for the quick reply...oh and thx for the config, also
02-25-2009 01:12 PM
router eigrp 123
net 172.12.0.0
redistr static
