Trying to authenticate managment users via IAS Radius
Feb 25th, 2009
I'm trying to setup my switches to authenticate users via Microsoft IAS to allow for management. I have followed may links I have found on the web, but I get a failure for some reason.
IAS shows the user has been granted access but the switch shows % Authentication failed.
I have this setup on one of my switches:
aaa new-model
aaa authentication login default group radius local
aaa session-id common
radius-server host auth-port 1812 acct-port 1813
radius-server key test
line vty 0 15
login authentication default
On the IAS remote policy I created, on the Advanced tab, I have tried to set the service-type to login and to Administrative. Also tried to add the cisco-av-pair for shell:priv-lvl=15 and tried using vedor specific, but no go.
I have looked at these links but still no go:
Overall Rating: 3 (1 ratings)
John Blakley Wed, 02/25/2009 - 12:54
I would try to run "debug radius" and see if you can get anything from that.
