6to4 anycast crashing 1812 router regularly
chrohmann
I setup IPv6 anycast (client) (RFC 3068) on my 1812 router. The router is using a pppoe dialer 1 via vlan 10 (FTTB-network that uses VLANs between vdsl-modem and IAD).
Here you go with the config:
--- cut ---
interface FastEthernet2
description WAN-link (VDSL Modem)
switchport mode trunk
interface Vlan1
ip address 192.168.xxx.254 255.255.255.0
ip nat inside
ip virtual-reassembly
ipv6 address localnet ::1:0:0:0:1/64
ipv6 nd prefix default 180 120
ipv6 nd ra interval 10
interface Vlan10
no ip address
pppoe enable group global
pppoe-client dial-pool-number 1
ipv6 unicast-routing
ipv6 general-prefix localnet 6to4 Dialer1
ipv6 inspect name ipv6inspect tcp
ipv6 inspect name ipv6inspect udp
ipv6 inspect name ipv6inspect icmp
vpdn enable
interface Tunnel64
description IPv6 6to4 tunnel
no ip address
no ip redirects
ipv6 enable
ipv6 traffic-filter no-ipv6-inbound in
ipv6 mtu 1472
ipv6 inspect ipv6inspect out
tunnel source Dialer1
tunnel mode ipv6ip 6to4
tunnel path-mtu-discovery
interface Dialer1
ip ddns update hostname HOSTNAME.dyndns.org
ip ddns update DynDNS
ip address negotiated
no ip redirects
no ip proxy-arp
ip mtu 1452
ip nat outside
encapsulation ppp
ip route-cache flow
ip tcp adjust-mss 1452
dialer pool 1
dialer vpdn
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username <A HREF="mailto:<A HREF="mailto:USERNAME@PROVIDER.TLD">USERNAME@PROVIDER.TLD</A>"><A HREF="mailto:USERNAME@PROVIDER.TLD">USERNAME@PROVIDER.TLD</A></A> password 0 PASSWORD
ppp ipcp dns request
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip nat inside source list 1 interface Dialer1 overload
ipv6 route ::/0 2002:C058:6301::
ipv6 access-list no-ipv6-inbound
deny ipv6 any any
--- cut ---
The thing is that everything just works just as expected. IPv6 RA (router solicitations) just appear after the tunnnel 64 is up and IPv6 internet can be used. After a while (I guess when the dialer needs to redial) this appears in the log:
--- cut ---
%DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
%LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to down
%LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel64, changed state to down
%DIALER-6-BIND: Interface Vi2 bound to profile Di1
%LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access2, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel64, changed state to up
%IP-3-DESTHOST: src=xx.xx.xx.xx, dst=0.0.0.0, NULL desthost -Process= "IPv6 IDB", ipl= 4, pid= 210, -Traceback= 0x808D0CE4 0x80CCD37C 0x80CCF1A4 0x80CCF964 0x80CCF9BC 0x81726BFC 0x80065370 0x81F253F4 0x81F26DC4 0x81E2FB84 0x81E063C8 0x81E0664C 0x81DF88A8 0x81DF8CD0 0x81DFE514 0x81DFBB00
%IP-3-DESTHOST: src=xx.xx.xxx.xx, dst=0.0.0.0, NULL desthost -Process= "IPv6 IDB", ipl= 4, pid= 210, -Traceback= 0x808D0CE4 0x80CCD37C 0x80CCF1A4 0x80CCF964 0x80CCF9BC 0x81726BFC 0x80065370 0x81F253F4 0x81F26DC4 0x81E2FB84 0x81E063C8 0x81E0664C 0x81DF88A8 0x81DF8CD0 0x81DFE514 0x81DFBB00
%IP-3-DESTHOST: src=xx.xx.xx.xx, dst=0.0.0.0, NULL desthost -Process= "MLD", ipl= 4, pid= 212, -Traceback= 0x808D0CE4 0x80CCD37C 0x80CCF1A4 0x80CCF964 0x80CCF9BC 0x81726BFC 0x80065370 0x81F253F4 0x81F26DC4 0x81E2FB84 0x81E063C8 0x81E08728 0x81E30A2C 0x81E10CD4 0x81E10D84 0x81E1064C
--- cut ---
Those entries are there everytime the dialer goes down and up again. The only way to gain connectivity back it by booting the router.
IOS: c181x-advipservicesk9-mz.124-11.XW9.bin
Laurent Aubert
Only the TAC will be able to analyse those logs and help you to find out the root cause of this issue.
Laurent.
