problem w/ dial up
Feb 25th, 2009
this is the result of mu debug:
Di1 DDR: No free dialer - starting fast idle timer
*Feb 25 19:24:54.581: %LINK-3-UPDOWN: Interface Async1, changed state to up
*Feb 25 19:24:58.533: TTY1: cleanup pending. Delaying DTR
*Feb 25 19:24:58.805: Di1 DDR: No free dialer - starting fast idle timer
*Feb 25 19:24:59.981: Async1: allowing modem_process to continue hangup
*Feb 25 19:25:00.025: Di1 DDR: No free dialer - starting fast idle timer
*Feb 25 19:25:00.533: TTY1: restoring DTRdeb
*Feb 25 19:25:00.637: Di1 DDR: No free dialer - starting fast idle timer
*Feb 25 19:25:00.805: Di1 DDR: No free dialer - starting fast idle timer
*Feb 25 19:25:01.025: Di1 DDR: No free dialer - starting fast idle timer
*Feb 25 19:25:01.457: Di1 DDR: No free dialer - starting fast idle timer
*Feb 25 19:25:01.981: %LINK-3-UPDOWN: Interface Async1, changed state to down..
What could it be?
regards.
vmoopeung Tue, 03/03/2009 - 19:38
  • Bronze, 100 points or more
If the physical interface is not associated with any pool, the debug message on the calling router will be the same as in the case where no more physical interfaces are available, causing the fast idle timer to trigger
*Mar 1 11:54:14.937: Di15: No free dialer - starting fast idle timer
Solution: Configure the dialer pool-member command on the physical interface to associate it to a dialer pool
