Adding ISP secondary subnet to 2801
maximtory
I can't seem to get the secondary IP subnet to get out from inside my LAN. I added the subnet as "secondary" and called my ISP to confirm their setting are set and routing the new subnet to our router. Am I forgetting to do something? Do I need to add a route on my router?
Thanks in advance for your help.
Chris
10 Replies 10
John Blakley
Can you post your config? What is the end goal? Are you getting new public addresses routed to you?
HTH,
John
HTH, John *** Please rate all useful posts ***
We are trying to add a second subnet to our inside interface. We are running out of IP's so we needed to add another set of IP's our ISP has given us.
running config(I took out the ACL's but let me know if you need them.):
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname router2801
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$bOqN$43j31EaIigZ57suJyXUE/0
no aaa new-model
resource policy
clock timezone Hawaii -10
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
ip tcp synwait-time 10
no ip dhcp use vrf connected
no ip bootp server
no ip domain lookup
ip domain name test.org
ip name-server z.z.z.z
username xxxxx privilege 15 view root secret 5 rtsghrthgrtygw5445y5yw4tgtr
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$$FW_INSIDE$
ip address y.y.y.y 255.255.255.0
ip route-cache flow
speed 10
full-duplex
no mop enabled
interface FastEthernet0/1
description $ETH-LAN$$FW_INSIDE$
ip address x2.x2.x2.x2 255.255.255.224 secondary
ip address x.x.x.x 255.255.255.224
ip access-group 101 in
ip access-group 102 out
ip route-cache flow
speed 100
full-duplex
no mop enabled
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.x.x(ISP Gateway) permanent
ip http server
ip http authentication local
ip http timeout-policy idle 5 life 86400 requests 10000
logging x.x.x.x
access-list 101 remark SDM_ACL Category=17
access-list 101
line con 0
login local
line aux 0
line vty 0 4
access-class 101 in
privilege level 15
password 7 04540703032E
login local
transport input telnet
line vty 5 15
privilege level 15
password 7 0209085E0709
login local
transport input none
end
Well, two things I see. You have access-groups assigned to your fa0/1, but you don't have the acls in the running config. Can you post those? Are you bridging this connection with your provider, and not routing?
HTH,
John
Chris
It is slightly hard to tell from the post which interface is inside and which is outside since they both have comments that indicate that they are inside. And the hiding of details of the default route makes it difficult to know quite what it is doing.
From the fact that there is no address translation configured would I assume that both x.x.x.x and x2.x2.x2.x2 are public addresses? Or would I be better to assume that the router connects to a firewall which does the translation?
If they are public IPs and there is no translation then I believe that John's suggestion that it may be the access list is probably the best quess.
And if there is a firewall which is doing translation then I believe that the best guess is that the firewall is not changed to handle the second subnet.
If you provide the appropriate details we might be able to give better answers.
Rick
Rick
Sorry for the confusion. The new subnet we are getting will be for the inside of our router. We use a 2801 with 1 external interface and 1 internal interface. We don't have a firewall yet so we have been told by our contractor to use additonal acl's to help with security. I have addedded x2.x2.x2.x2 as a "secondary" subnet on the inside, but we still only have 1 ip on our external int and 1 on the single interface(x.x.x.x).
Basically the only line I added to our current config is "ip address x.x.x.x 255.255.255.224 secondary"
We didn't add any other routes or acl's. Do we need to, that is where I am having some confusion. The ISP tech said they are already routing the new subnet to our router, and we wouldn't have to do anything. But I am assuming I have to configure the router to allow the new subnet to get in and out. We have a lot of acl's let me know if you need me to add them to this. Thanks for all your help.
Chris
The additional information is helpful. And I believe that it confirms that both addresses on the "inside" interface are public addresses which do not require address translation. If the ISP tech says that they are already routing that subnet to you then you certainly do not need to add any routes or anything like that. I suspect that you do need to change one or both of the access lists. It would be very helpful if you would post them. (and we may need a bit more detail than x.x.x.x and x2.x2.x2.x2 for addressing)
Also I note that you seem to be using access list 101 as an interface access list using access-group and also using the access list on the vty with access-class. While it is possible to use the same access list for both it is very unusual. I would suggest that you use a different access list (and probably a standard access list rather than an extended access list) for the access-class on the vty.
Rick
Rick
!version 12.4
no service pad
hostname ro01-map
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
no ip bootp server
no ip domain lookup
ip name-server 216.36.57.90
ip name-server 68.215.210.50
username dfsg privilege 15 secret 5 $1$KLBE$YdnM/NzfpVAt9vOaOtIiW0
username hlffd privilege 15 secret 5 $1$mUQH$9hKPSVXg/d8d6MupjTc04.
username oledflfddm privilege 15 view root secret 5 $1$qODq$yeCrO4WqfVxjGwyluwY/e/
ip address 66.93.59.220 255.255.255.0
ip route-cache flow
speed 10
full-duplex
no mop enabled
ip address 74.202.18.25 255.255.255.224 secondary
ip address 68.215.228.190 255.255.255.224
ip route-cache flow
speed 100
full-duplex
no mop enabled
ip classless
ip route 0.0.0.0 0.0.0.0 66.193.159.1 permanent
ip http server
logging 68.215.228.179
access-list 101 permit tcp 68.215.228.160 0.0.0.31 any log
access-list 101 permit udp 68.215.228.160 0.0.0.31 any log
access-list 101 permit icmp any 68.215.228.160 0.0.0.31 log
access-list 101 permit tcp any host 68.215.228.163 log
access-list 101 permit tcp host 71.42.114.242 host 68.215.228.164 eq www log
access-list 101 permit esp 68.215.228.160 0.0.0.31 any log
access-list 101 remark DMZ any to inside allow changed to ftp server
access-list 101 permit tcp host 68.215.228.175 any log
access-list 101 remark NTP
access-list 101 permit udp any host 192.5.41.41 eq ntp log
access-list 101 deny ip any any log
access-list 102 remark SDM_ACL Category=17
access-list 102 permit ip any 68.215.228.176 0.0.0.15 log
access-list 102 permit tcp any 68.215.228.160 0.0.0.15 established
access-list 102 permit icmp any 68.215.228.160 0.0.0.31 log
access-list 102 permit tcp any host 68.215.228.175 eq ftp log
access-list 102 permit tcp any 68.215.228.160 0.0.0.15 eq www log
access-list 102 permit tcp any host 68.215.228.163 eq 443 log
access-list 102 permit tcp any host 68.215.228.163 eq smtp
access-list 102 permit tcp any host 68.215.228.163 eq 1025 log
access-list 102 permit tcp any 68.215.228.160 0.0.0.15 eq 5900 log
access-list 102 permit tcp any 68.215.228.160 0.0.0.15 eq 8080 log
access-list 102 permit udp any 68.215.228.160 0.0.0.31 log
access-list 102 permit esp any 68.215.228.160 0.0.0.31 log
access-list 102 permit tcp any 68.215.228.160 0.0.0.31 eq 15868 log
access-list 102 permit tcp any 68.215.228.160 0.0.0.31 eq 993 log
access-list 102 permit tcp 68.215.228.192 0.0.0.63 any eq 22 log
access-list 102 permit icmp 68.215.228.192 0.0.0.63 any log
^C
line con 0
login local
line aux 0
line vty 0 4
access-class 101 in
privilege level 15
password 7 04540703sdfsf032E
login local
line vty 5 15
privilege level 15
password 7 0209085E07ssdfsd09
login local
end
Sorry it took so long to get back to you. Here is the running config ith the IPs changed.
Chris
Thank you for posting the additional details. It does confirm that your problem is with the access lists. I see several problems with the access lists. The biggest problem is that the inbound access list 101 does not have any permit statements for anything in 74.202.18.0/27 as the source (remember that inbound access lists are for traffic from the LAN coming into the interface, so the LAN is the source address). And the outbound access list 102 does not have any permit statements for the new subnet either (remember that in outbound access lists the local subnet is the destination).
So the most important thing that you need to do is to add permit statements to both access list 101 and 102 to permit the new subnet. At a minimum it might look like:
access-list 101 permit ip 74.202.18.0 0.0.0.31 any
and
access-list 102 permit ip any 74.202.18.0 0.0.0.31
and if your requirements are to treat different hosts differently (as the access list does for the original subnet) then you would need to create that logic.
There are some other issues in the access lists, but they are not involved in why the new subnet does not work.
- these 2 lines use 68.215.228.160 as the destination, but are in the inbound access list where that subnet should be the source and not the destination:
so I do not see how these lines could ever get a hit.
- this line also has the addresses reversed from what they should be:
- and access list 102, which is outbound, has these lines where the source and destination are reversed:
Fix up the access lists and let us know how it is working.
Rick
Rick
Thanks for your help so far, I really appreciate it. I have made the changes, but seem to still have difficulty getting to the router from the device. What would I use for the gateway when adding a static IP to a device? Thanks again for your help.
maximtory
Thanks, Rick.
It looks like its working now, it looks like we can put in either gateways in(the old or new subnet gateway). Thanks for your help, you guys are the best. If you have any other suggestions on things we can change on our ACL's/running config we would totally appreciate it as well.
