ISDN connectivity
Feb 25th, 2009
We have a new ISDN router Cisco 3845 connecting to Cisco 7600 Leased line router.We would like to use ISDN as backup.I have attached the network diagram.
Query:
1.Referring to diagram, what is the best way to configure interface A&B and C&D.Is it better to create an L3 port-channel or do we create the bridge group between A&B and C&D ?
2.How the routing will take place when the Leased line will go down if we use bridging between 3845 & 7600?
Rgds./Sack
Paolo Bevilacqua Wed, 02/25/2009 - 13:30
No, you never use bridging for backup.
Configuring backupo correctly can be tricky and require professionality.
Recommend you hire a certified/experienced person for the job.
