Bulk Voice Mail changing - Unity Connection
Answered Question
Feb 25th, 2009
Is there a way to set a default Voice Mail Connection password for all users.As soon as the users dials the VoiceMail Hunt Pilot , he is asked to change his password.
thanks
Correct Answer by Rob Huffman about 8 years 4 months ago
Hi Ramzi,
For Unity Connection the default password for users is setup in the VM Template that is used to create new users :)
Do the following procedure for user accounts, or for a template that you will use to create user accounts.
To Change a Phone (PIN) Password for an Individual User or Template
Step 1 In Cisco Unity Connection Administration, find the template that you want to edit.
Step 2 On the Edit menu, click Change Password.
Step 3 In the Choose Password list, click Voice Mail.
Step 4 In the Password field, enter the new password.
Step 5 In the Confirm Password field, reenter the password to confirm.
Step 6 Click Save.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/2x/user_mac/guide/2xcucmac040.html#wp1054468
Then check the option " User Must Change at Next Login" to force them to setup a new "personal" password.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Hythim Ali El Hadad Wed, 02/25/2009 - 14:21
  • Silver, 250 points or more
Hi Tka,
I think it will be as i do in unity 4.0,
It is when you create the subscriber,
He will be assigned the password configured in the user conf page
And in his first access to unity, he will be asked to change his password by default
Wish this be helpful
tka@tn.ibm.com Wed, 02/25/2009 - 22:55
Hi ,
First ,thansk for your reply
Actually, I'm talking about Unity Connection and not Unity so the concept of Subscriber is inexistant
regards,
Correct Answer
Rob Huffman Thu, 02/26/2009 - 06:26
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ramzi,
Step 6 Click Save.
Hope this helps!
Rob
