Caller ID presentation
Hythim Ali El Hadad Wed, 02/25/2009 - 14:18
When you fill the Display (Internal Caller ID) and the Alerting Name
in your line configuration [in case of a device or a device profile] , you will have a caller ID presenation instead of your DN.
Then if you need to control if you need to display the DN or not,it is by enabling the check box in your line configuration also.
Hythim Ali El Hadad Thu, 02/26/2009 - 02:52
Hi tka,
Yes, the extension mobility use the device profile that you will fill the 2 fields i have asked you to fill in my last mail
you must fill these fields in the device profile with the same first and last names you did in the user configuration to be the same as you want
I wish this be helpful
