Voice Name PLAY/RECORD field in th eUnity Connection Edit User Basics
Jaime Valencia Wed, 02/25/2009 - 13:52
that's the recorded voice, to put it simply it's your name recorded by you
the one you get when you check your VMs if you enabled unity to greet you with your name or when you leave a VM to other user so they hear your name and not the DN
if you want to use dial by name it's also mandatory to define it.
if this helps, please rate
