bansal.ojasvi Wed, 02/25/2009 - 13:51
What all options are you looking for? I have done
ip dhcp pool VOICE
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
domain-name voice.local
dns-server 4.2.2.1 4.2.2.2
option 42 ip 192.168.10.1 (for NTP)
option 66 ip 192.168.10.10 (for TFTP)
lease infinite
vineesh.viswanath Wed, 02/25/2009 - 13:55
Bansal .
Thanks for the post.
My problem is both phone and pc are getting same IP Range , ie Data VLAN .
I am using siemens optipoint phone and i know that there are some extra configurations in windows DHCP server .
will the phone get IP without the DHCP Option values set .
John Blakley Wed, 02/25/2009 - 14:12
  • Purple, 4500 points or more
Your phone will get an ip from whatever vlan it's connected to. Generally, if you're going to run your DHCP scope on your router, you'll need to configure router-on-a-stick and put your phones in a separate vlan.
Example:
int fa0/0
no ip address
int fa0/0.1
desc data vlan
encapsulate dot1q 1 native
int fa0/0.10
desc voice vlan
encapsulate dot1q 10
ip address 192.168.10.1 255.255.255.0
Your dhcp scope will look like:
ip dhcp pool DATA
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
ip dhcp pool VOICE
You'll set your phone to talk on VLAN 10, and it *should* get an address from the VOICE pool.
HTH,
John
bansal.ojasvi Wed, 02/25/2009 - 14:20
Also make sure that the VLAN enable option on the phone is also enabled.
I know with Cisco phones, the phones automatically detects the VLAN and puts the lan port in the correct VLAN.
OJ
vineesh.viswanath Wed, 02/25/2009 - 14:21
that,s brilliant .
But , how will the switch get to know that the packet from the phone is the exact voice vlan ?
Scenario: c4500
int fa1/1
switchport access vlan 10
switchport voice vlan 100
auto qos trust dscp
vlan 10: 192.168.10.0/24
vlan 100: 192.168.100.0/24
scope 1 :
network 192.168.10.0/24
scope 2
network 192.168.100.0/24
exclude svi address .
when the phone boots up , its getting ip address in the range 192.168.10.0 which is the data side .
even the pc get the same range .
John Blakley Wed, 02/25/2009 - 14:25
Vineesh,
I was under the impression that Voice vlans as in "switchport voice vlan" only works with Cisco phones. If you have a different type of phone, you may have to configure it as a trunked port and then set your phone to the correct vlan. I'm not a Cisco VoIP person though, but this is how Avaya phones are set up.
I would configure the port that your phone is connected to as a trunked port (if your pc connects to the phone) or as an access port of the particular vlan that you create for voice only (if your phone is directly connected to a port without a PC attached).
HTH,
John
*please rate if helpful*
John Blakley Wed, 02/25/2009 - 14:30
TAC tried what?
The next thing I would do is put the phone directly to the port, set the port to access for the vlan that you want to get an address for, and see if it works that way. Can you post your config for your DHCP scope, your port that the phone connects to, and the interface for the VLAN that you've configured?
John
John Blakley Wed, 02/25/2009 - 14:34
I reread your OP, and I didn't see where you had a scope on your Windows server. Do you have a helper address configured on the interface for the vlan that the phone is coming in on?
What kind of equipment are you working with? Is it the 4500?
John
vineesh.viswanath Wed, 02/25/2009 - 14:37
its c4500 switch .
DHCP is configured in the same switch .
i haven't configured helper address
vineesh.viswanath Thu, 02/26/2009 - 11:13
The problem is due to not configuring option 43 .
please let me know if anyone ve configured option 43
eg
option 43 ascii "Siemens,VLAN"
the phone is not accepting this .
bansal.ojasvi Wed, 02/25/2009 - 14:25
The link between the phone and the switch is mini-trunk. The phone will mark the packets on Vlan 100 with vlan tag and will not mark the packet from Vlan 10. That's how the switch will recognize the different VLAN packets.
OJ
vineesh.viswanath Fri, 02/27/2009 - 09:23
The issue is resolved .
i had to put option 60 and 43 on the primary [data] dhcp scope .
