Unity Connection reporting not showing full extension
kwaldecker
Hi all,
I am working on a Unity Connection 2.1.2.100.
I run a user report under the serviceability menu and get a report of all users.
The problem i have is on the report, any extension that is more than 5 digits it cuts it off.
so for extension 1005678 all i get on the report is 10056.
anyone seen this before?
thanks
Ken
testeven
Hi Ken!
Seems you are hitting a known bug: CSCsx42105
Reports: Extensions longer than 5 digits are truncated
When running reports in UC 7.0(1), user's extension longer than 5 digits are truncated.
Symptom:
When run in .csv or web output, extensions longer than 5 digits are truncated.
Conditions:
UC 7.0(1)
Workaround:
None.
This is fixed in 7.0(1) and 7.0(2) so you'll need to upgrade to 7.0 and open a case with TAC to get an ES with the fix.
Hope this helps!
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
