Cisco Aironet 1300 QoS
Feb 25th, 2009
Hello, I have 2 Cisco Aironet 1300 Bridges which provide data and voice communication between 2 buildings. Up until recently QoS has not been needed, but lately there appears to be congestion due to reports of poor voice quality. Building A houses a V3000 NBX Telephone system, Building B houses approximately 30 remote IP phones. Building A and Building B are approximately 100 yards apart. No VLAN's. Due to myself being an extreme noob to Cisco bridges, I was hoping some of you may have had experience in setting this up and hopefully provide some tips. I need to prioritize traffic on UDP ports 2093-2096 and TCP port 1040. Thank you in advance for any suggestions. My current running config is below:
Using 1283 out of 32768 bytes
version 12.3
no service pad
service password-encryption
hostname LHS-WeightRoom-WCV
ip subnet-zero
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
dot11 ssid wcv
authentication open
guest-mode
dot11 ssid wcvcisco
authentication open
infrastructure-ssid optional
username root privilege 15 password 7 0247335A05320A2244
username Cisco privilege 15 password 7 074E164D403D1C061F
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid wcv
ssid wcvcisco
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root bridge
bridge-group 1
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
bridge-group 1
hold-queue 80 in
interface BVI1
ip address 10.141.8.6 255.255.254.0
no ip route-cache
ip default-gateway 10.141.8.5
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
end
