don't permit entry duplex full command in a gigabitethernet interface
harold.morales
I have in the network switches 2960 and 3560, but don't can type in CLI the duplex full, speed command.
the IOS in the switches is 12.2(35)SE5
thanks.
SW_NEIV_01(config)#inter gigabitEthernet 0/2
SW_NEIV_01(config-if)#
SW_NEIV_01(config-if)#du
SW_NEIV_01(config-if)#duplex?
% Unrecognized command
SW_NEIV_01(config-if)#duplex full
% Invalid input detected at '^' marker.
SW_NEIV_01(config-if)#speed
2 Accepted Solutions
hobbe
Level 7
Level 7
There is only full duplex with gigabit.
There is no such thing as gig/half-duplex. No matter if it is copper ports or fiber ports.
Maybe it's the IOS. I was able to change duplex and speed on another switch which had a gigabit copper sfp.
Mohamad
21 Replies 21
bansal.ojasvi
I had the same issue on my 3750 and found out that a port in routed state can be configured for speed and duplex and a switchport cannot be. Let me know if you find more information.
OJ
this teh configuration in the interfaces:
SW_NEIV_01#sh run inter gigabitEthernet 0/1
Building configuration...
Current configuration : 59 bytes
interface GigabitEthernet0/1
switchport mode trunk
end
if you need more information, please tell me
Mohamad Qayoom
Level 3
Level 3
Can you please post results from : "sh run int gi0/2"
Mohamad
only had configured this:
SW_NEIV_01#sh run inter gigabitEthernet 0/2
interface GigabitEthernet0/2
end
What's you media-type? Are you using fiber SFP? If so, you can't specify duplex because it's full duplex by nature.
Here's the output from my switch.
Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000BaseTX SFP.
I think you can still change the speed/duplex if the port is routed and not switchport.
I don understand what is a port routed or how is the configuration for put a switch port routed?
no, don't is fiber is utp pair twister
Change it to a non trunk port and then change the speed and duplex.
i tried change this but still don't works
SW_NEIV_01#sh run inter giga 0/2
end
SW_NEIV_01#conf ter
Enter configuration commands, one per line. End with CNTL/Z.
SW_NEIV_01(config)#inter giga0/2
SW_NEIV_01(config-if)#no switchport mode trunk
mqayoolsuhsc is right. Your media type shows that Gig 0/2 is using a GLC-TX. This SFP will NOT negotiate speed/duplex setting. GLC-TX SFP negotiates to speed 1000 and FULL Duplex, period.
Hope this helps.
hobbe
Level 7
Level 7
i belive that the matter is for the IOS: 12.2(35)SE5
Mohamad
