CUCM LDAP integration
Answered Question
Feb 25th, 2009
Hi All,
how can I force LDAP synch? is there any commnad on CLI? I am using CUCM 7.0.
thanks
Alex
Correct Answer by Jaime Valencia about 8 years 3 weeks ago
no, once you define the entries when you look at them from ldap directory you get the option to force resync.
if this is the 1st time you define it, complete that step and then go into the entry again after you finish
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Jaime Valencia Wed, 02/25/2009 - 14:36
  • Cisco Employee,
  • Hall of Fame,
    2011
under ldap directory entry there's the option
java
alex goshtaei Wed, 02/25/2009 - 14:40
thanks for quick response, you mean "perform sync just once" option?
Correct Answer
Jaime Valencia Wed, 02/25/2009 - 14:42
  • Cisco Employee,
  • Hall of Fame,
    2011
java
