Route manipulation
Feb 25th, 2009
  • Bronze, 100 points or more
I'm injecting static routes into EIGRP.
Is there any way to have a redistributed static route leave the EIGRP routing table when it's no longer use?
Or is there any kind of way for a route to recognize "something" ie another route, vpn or anything and then inject itself into EIGRP?
paolo bevilacqua Wed, 02/25/2009 - 15:04
  • Hall of Fame,
    Founding Member
define "no longer use".
yes, static routes can be subject to tracking objects. That is a last resort configuration however, often there are alternatives.
DialerString_2 Thu, 02/26/2009 - 08:21
Belivacua thanks for the reply and disregard my ignorance. I jump the gun and hit me this morning around 2 a.m.! I don't need that route to be redistributed at all, so I just manipulated the acl.
Can you tell me about the tracking objects or point me to a good link?
thx
Giuseppe Larosa Thu, 02/26/2009 - 11:34
  • Hall of Fame,
    Founding Member
Hello Eric,
here it is a link to reliable static routing and object tracking
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html')">http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html
using this feature the state of a static route is subject to the track test you define.
To be noted that a static route can be removed from the routing table even without using this feature when the outgoing interface fails for example.
Redistribution is a dynamic process executed from time to time and so a static route removed from the routing table is going to be removed also from EIGRP updates and database
Hope to help
Giuseppe
