ASA 5510 remote management via vpn client
Feb 25th, 2009
I need to manage an ASA 5510 by remote using a Cisco vpn client.
I have a 7.2(1) an it's running. I logged into the vpn and ssh I can connect the inside IP of the ASA. I cannot ping the inside IP!
Trying the same scenario on another 5510 with ASA 7.2(4) doesn't work.
Any help?
Regards, Celio
Overall Rating: 4 (1 ratings)
JORGE RODRIGUEZ Wed, 02/25/2009 - 21:30
  • Green, 3000 points or more
Celio,
Does your config have management-access statement anywhere?
in order to manage the ASA via VPN tunnel you need management-access statement.
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/m.html#wp1987122
typical statement
asa(config)#management-access inside
if management0/0 is your only management interface defined by statement under the interface you may need
management-access management
try these and let us know if issues.
PLS rate any helpful posts
celiocarreto Fri, 03/06/2009 - 01:28
Hi Jorge,
I tried different combinations of management-access.
Under 7.2(1) I have no such command and it works!
Under 7.2(4) I configured:
ssh RA-VPN-IP inside
and it works!
Thx for your help.
Celio
