Mac address of serial interface of router
Answered Question
Feb 25th, 2009
Hi all,
Here is exam question
Pc is conected to switch ,and switch is connected to router r1.Router r1 has serail connection to ISP router.
We are accessing remote server.when frame leaves router R1 serial interface will it carry any mac address or not.
many thanks
mahesh
Correct Answer by Richard Burts about 8 years 2 months ago
Mahesh
To helpfully understand this question and its answer we should start by reviewing a few fundamental concepts about layer 3 addressing and about layer 2 addressing.
The layer 3 addressing is IP addressing. And a fundamental concept is that as a packet is forwarded from the source to the destination that the IP addresses (the source address and the destination address) remain the same all the way through. So all the way, over all the different segments that it may travel it will have the same source IP address and the same destination IP address.
The layer 2 addressing depends on the individual segment. If it is Ethernet then the layer 2 address is a MAC. And if the layer 2 is Frame Relay then the layer 2 address is the DLCI. And the fundamental concept is that as a packet is forwarded through the network the layer 2 address is unique to the local segment and will change as the packet is forwarded over different segments. So as a packet is forwarded over a segment its layer 2 source address represents the interface that sends it onto that segment and its layer 2 destination address represents the interface that is its next hop toward the destination.
So for example if a packet is received by a router on an Ethernet interface and is forwarded out another Ethenet interface, then the packet had a source MAC address when recieved on one Ethernet interface and it has a different source MAC when it is forwarded out the next interface.
And if a packet is received by a router on an Ethernet interface it will have source and destination MAC addresses. And when it is forwarded out the outbound interface it will have layer 2 addresses consistent with the outbound interface. If the outbound interface is Frame Relay then the layer 2 address is the DLCI and there is no MAC address. And if the outbound interface is HDLC or PPP it will have the layer 2 addresses of those protocols and there is no MAC address.
Rick
Correct Answer by badalam_nt about 8 years 2 months ago
MAC address is used only on Ethernet interfaces, not on serial ones.
For your specific case, probably you have used HDLC on your serial interface.
The router just fill in that HDLC frame with the necessary header info, encapsulates the IP packet and passes the frame then on its serial interface.
The router does not need to know any info about the destination L2 address, so the router just sends the frame out the corresponding serial interface.
Correct Answer by Roberto Salazar about 8 years 2 months ago
Serial interfaces does not have mac addresses, so the answer would no mac-address.
Overall Rating: 5 (6 ratings)
Correct Answer
Roberto Salazar Wed, 02/25/2009 - 16:06
  • Gold, 750 points or more
mahesh18 Wed, 02/25/2009 - 16:19
Hi bosalaza,
thanks for reply
can you explain me please how packet
will move from one serial int of router to another serial interface with out
MAc
mahesh
Correct Answer
badalam_nt Wed, 02/25/2009 - 16:31
Roberto Salazar Wed, 02/25/2009 - 18:50
It will depend on what encapsulation the serial interface is using, for example on frame relay, you will map an ip for example to a dlci.
badalam_nt Wed, 02/25/2009 - 19:29
Yes of course, that is true, for Frame Relay you need this mapping IP@ to DLCI.
As the question was not pointing to a frame relay, I assumed it is the default encapsulation (HDLC) and my comment was around HDLC only, not generalizing for all L2 types.
But it is maybe better you pointed this out, it will exclude any possible confusion.
Correct Answer
Richard Burts Wed, 02/25/2009 - 20:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Mahesh
Rick
mahesh18 Thu, 02/26/2009 - 07:03
Hi Bosalaza,
Many thanks for your reply
mahesh
