GetVPN KS and GM on the same box
Answered Question
Feb 25th, 2009
I'm trying to setup network using GetVPN instead of standard IPSec tunnels and was trying to get the KS and GM to be on the same box, is this possible? If so does somebody have a config example.
Andrew
Correct Answer by ajagadee about 8 years 2 months ago
Hello Andrew,
It is my understanding that KS and GM on the router is not supported.
Arul
*Pls rate all helpful posts*
Overall Rating: 5 (1 ratings)
Correct Answer
ajagadee Wed, 02/25/2009 - 19:40
  • Cisco Employee,
Hello Andrew,
Arul
