7606 Fiber connection question
Answered Question
Feb 25th, 2009
Hello
I have a Fiber link in place and would like to plug in 2 7606 routers on either end on this link.
Does the 7606 have the capability to connect to FX? If not, can I insert a PA with Fiber connectors (like an OC1)?
wvw
Correct Answer by Leo Laohoo about 8 years 2 months ago
You sure can. You can either use GLC-FE-100FX or GLC-FE-100LX.
Here's the link of supported SFP modules (FastEthernet and GigEthernet) for the 7600 routers:
http://www.cisco.com/en/US/docs/routers/7600/Hardware/12.2SR_supported_hw/7600_hwd.html#wp1270293
Hope this helps you.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Thu, 02/26/2009 - 01:40
  • Hall of Fame,
    Founding Member
Yes, you have all types of fiber interfaces on the 7600 routers, including 10 gigabits. What you choose depends by your fiber plant, and budget.
willemvwyk Thu, 02/26/2009 - 12:46
We are looking at a fiber link with an LC connector which in turn has to plug into the 7606 router. Any suggestions?
viyuan700 Thu, 02/26/2009 - 16:20
  • Silver, 250 points or more
I think more than LC connector you should provide info what speed you are looking for and what is the distance between 2 routers?
LC is just the connector even if the card for the speed and distance dont have LC connector. you can buy a cable which will convert to LC connector at the end.
paolo bevilacqua Thu, 02/26/2009 - 16:25
  • Hall of Fame,
    Founding Member
Please specify fiber type and length of span.
Correct Answer
Leo Laohoo Thu, 02/26/2009 - 14:20
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Leo Laohoo Thu, 02/26/2009 - 19:19
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the rating.
