ACE: Problem dual proccesor server predisctor least-load and 2 oids
Feb 25th, 2009
I have a problem, I have configured predictor least-loaded and probe snmp in ACE, My Servers are dual core proccesor. the oids are:
oid .1.3.6.1.2.1.25.3.3.1.2.1 and oid .1.3.6.1.2.1.25.3.3.1.2.2
In 1 context (integracion1) I configured oid .1.3.6.1.2.1.25.3.3.1.2.1 and the other context (integracion2) I configured oid .1.3.6.1.2.1.25.3.3.1.2.2 and the results was positive, but when I configure 2 oid in integracion2 the output says FAILED, I need sense 2 proccesors to balance. how can do it? when I configure .1.3.6.1.2.1.25.3.3.1.2 (2 proccesors) the output says FAILED
I attachment 3 configurations
Best Regards
litrenta Thu, 02/26/2009 - 05:40
  • Cisco Employee,
when you use multiple oid's on a probe , you need to manually configure the weight and make sure weights add up to 16000 so your probe should be configured as follows:
probe snmp test-server
interval 4
faildetect 2
passdetect interval 10
receive 2
community public
threshold 75
weight 8000
threshold 75
weight 8000
