Unable to receive incoming calls
Feb 25th, 2009
I'm using cm 6.1 using fxo to make outgoing calls. But i cant receive incoming calls. May I know where the problem lies on? Thanks
iptuser55 Thu, 02/26/2009 - 03:22
What are the CSS for the FXO`s do they contain the Partitions for the DN`s, are numebrs translated? Do a DNA on the Gateway first and see where the issue is-
David Hailey Sun, 03/01/2009 - 18:05
You should create a CSS (e.g., CL_PSTN-In_CSS) and it should contain the partition where primary DN's exist, public service numbers (public voicemail pilot, etc), etc. Your gateway should use this CSS to route calls to direct calls to internal stations.
