Having trouble making a VPN connection w/UC520
Feb 25th, 2009
I am attempting to setup my uc520 to accept a VPN connection so I can use CCA remotely.
Attached is my screen shot of the configuration I made with CCA.
I am attempting to connect withVPN client 5.0.03.0560
The connection fails, terminating locally with "Reason 414: Failed to estatblish a TCP connection"
the connection entry on the client has user and password set as the user I added in CCA, group authentification, transport set a IPSec of TCP port 1000, transparent tunnelling enabled.
Any help as to what I am missing is appreciated.
Marcos Hernandez Wed, 02/25/2009 - 18:56
  • Blue, 1500 points or more
Try this:
1) Paste the text below into Notepad.
2) Replace the highlighted parameters with your Site Description, FE0/0 IP address or name (If using DDNS) and the Group password.
3) Save to a file using a .pcf (dot pcf) extension.
4) Import from your Cisco VPN CLient.
5) Try to connect from the WAN side.
Let me know,
Marcos
[main]
UserPassword=
enc_UserPassword=
Description=My Site
Host=A.B.C.D
AuthType=1
GroupName=EZVPN_GROUP_1
GroupPwd=XXXXXX
enc_GroupPwd=
EnableISPConnect=0
ISPConnectType=0
ISPConnect=
ISPPhonebook=
ISPCommand=
Username=
SaveUserPassword=0
NTDomain=
EnableBackup=0
BackupServer=
EnableMSLogon=1
MSLogonType=0
EnableNat=1
TunnelingMode=0
TcpTunnelingPort=10000
CertStore=0
CertName=
CertPath=
CertSubjectName=
CertSerialHash=00000000000000000000000000000000
SendCertChain=0
PeerTimeout=90
EnableLocalLAN=0
mcastrigno Wed, 02/25/2009 - 21:59
Marcos,
It did not work but I don't know what the group password is. See log below from client
Where in CCA do I set the group password?
I see the group you mention in CCA but nowhere to set the password.
1      23:01:01.953  02/25/09  Sev=Warning/3 IKE/0xE3000057
The received HASH payload cannot be verified
2      23:01:01.953  02/25/09  Sev=Warning/2 IKE/0xE300007E
Hash verification failed... may be configured with invalid group password.
3      23:01:01.953  02/25/09  Sev=Warning/2 IKE/0xE300009B
Failed to authenticate peer (Navigator:904)
4      23:01:01.953  02/25/09  Sev=Warning/2 IKE/0xE30000A7
Unexpected SW error occurred while processing Aggressive Mode negotiator:(Navigator:2238)
Marcos Hernandez Thu, 02/26/2009 - 06:15
Group password is the Pre-shared Key (PSK) in CCA.
Let me know,
Marcos
mcastrigno Thu, 02/26/2009 - 06:52
Marcos,
I am no longer on site and cannot access the router via CCA but I can telnet to it.
How do I set this password via the CLI?
Marcos Hernandez Thu, 02/26/2009 - 06:55
Replace where indicated:
crypto isakmp client configuration group EZVPN_GROUP_1
key REPLACE
pool EZVPN_POOL_1
max-users 10
Marcos
mcastrigno Thu, 02/26/2009 - 13:55
almost there.
I was presented with dialog box for username and password by the client but failed to make connection.
Here is what the log had after that point:
Cisco Systems VPN Client Version 5.0.03.0560
Copyright (C) 1998-2007 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 3
11     14:54:03.843  02/26/09  Sev=Warning/2 IKE/0xE3000023
No private IP address was assigned by the peer
12     14:54:03.843  02/26/09  Sev=Warning/2 IKE/0xE300009B
Failed to process ModeCfg Reply (NavigatorTM:175)
Thanks for your help.
Marcos Hernandez Thu, 02/26/2009 - 13:57
At this point you enter one of the usernames and password that you configured under the VPN screen in CCA.
Let me know,
Marcos
mcastrigno Thu, 02/26/2009 - 14:01
Marcos,
Sorry that was not clear in my message, but I did put in the username and password that I configured with CCA
Matthew
mcastrigno Thu, 02/26/2009 - 14:34
Thanks Steve, Looks like page 12 may be relevant.
How do I do this from the CLI since I don't have  CCA access yet until I get this to work?
What do you think Marcos?
Thanks.
Steven DiStefano Thu, 02/26/2009 - 14:53
Well, page 12 is for the PC Client on the Remote Teleworker.  So maybe not so relevant.
The thing is, you need to create the VPN Server on the Main UC500 before you connect the PC with Cisco VPN CLient.  For that, look at page 11, about half way down.   Make sure you set a DHCP Pool on the Host for remote connecting clients.
Using CCA on the main site (prerequisite), go to Configure SecurityVPN Server and provision:
user ID :  xxxxx
password: xxxxxx
Secret Key: xxxxxxx
local IP Address pool: 192.168.10.101 …110
The VPN Client must match this information like this...
mcastrigno Thu, 02/26/2009 - 15:15
Steve,
Your screen shot is not readable - can you post it as file?
Also there is a missing image in your post  - this is a cut and paste - can you repost whatever this is?
I cannot access CCA for the "main" (and only site) I am 90 miles away. That is why I am trying to set this up.
How can I do what you suggest with the CLI?
Thanks.
mcastrigno Thu, 02/26/2009 - 16:45
This problem was fixed by doing an OOB configuration change for the access lists.
The access lists were prevoiusly deleted by CCA after it encountered an aparently non-compatible configuration
So this problem was basiclly a hangover from the problem of CCA deleting access lists.
Moderator Fri, 02/27/2009 - 07:08
Here's a neat trick: If you click on the screenshot, it will expand out larger and will be easier to read. Most images in discussions and documents should do this.
Glad to hear the problem was solved.
Cisco Moderation Team
Related Content
