Dial Plan Question
Feb 25th, 2009
I want to send a call to an external trunk if there are no matches in internal partition or DNs. Is it possible to do?
For example, i dial 4digit extension and if there is no internal DNs matching it, should attempt on another trunk which will send the call to a pbx.
Nicholas Matthews Wed, 02/25/2009 - 19:12
  • Red, 2250 points or more
If this is CUCM:
You can create a route pattern that is less specific that any other pattern - such as XXXX. The other patterns will be more specific and be preferred, but if there isn't a match this route pattern would be used.
If this is CME:
You would want to create a dial peer with a destination-pattern of .T - the same principles apply here.
hth,
nick
