cannot manage to sync with ntp authentication
Feb 25th, 2009
ntp server whatever source outside prefer ... is working flawlessly but when I try:
name 192.5.41.209 server-ntp-USNO description US Naval Obervatory
name 128.115.14.97 server-ntp-LLL description Lawrence Livermore Laboratory
ntp authentication-key 1 md5 * (where * is an arbitrary 32-character string; ie: a user-defined random-string am I right ?)
ntp authentication-key 2 md5 * (another different one)
ntp authenticate
ntp trusted-key 1
ntp trusted-key 2
ntp server server-ntp-LLL key 2 source outside
ntp server server-ntp-USNO key 1 source outside prefer
the above example is more-or-less out of the PIX documentation but as you can see:
firewall# show ntp status
Clock is unsynchronized, stratum 16, no reference clock
nominal freq is 99.9984 Hz, actual freq is 99.9984 Hz, precision is 2**6
reference time is 00000000.00000000 (06:28:16.000 UTC Thu Feb 7 2036)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 0.00 msec, peer dispersion is 0.00 msec
firewall# show ntp associations detail
128.115.14.97 configured, insane, invalid, unsynced, stratum 16
ref ID 0.0.0.0, time 00000000.00000000 (06:28:16.000 UTC Thu Feb 7 2036)
our mode client, peer mode unspec, our poll intvl 64, peer poll intvl 64
root delay 0.00 msec, root disp 0.00, reach 0, sync dist 0.000
delay 0.00 msec, offset 0.0000 msec, dispersion 16000.00
precision 2**5, version 3
org time 00000000.00000000 (06:28:16.000 UTC Thu Feb 7 2036)
rcv time 00000000.00000000 (06:28:16.000 UTC Thu Feb 7 2036)
xmt time cd508e71.b903bb88 (03:43:45.722 UTC Thu Feb 26 2009)
filtdelay = 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
filtoffset = 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
filterror = 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0
192.5.41.209 configured, insane, invalid, unsynced, stratum 16
org time cd508e75.72d7dc0f (03:43:49.448 UTC Thu Feb 26 2009)
rcv time cd508e73.e8c22140 (03:43:47.909 UTC Thu Feb 26 2009)
xmt time cd508e73.b9046392 (03:43:47.722 UTC Thu Feb 26 2009)
what I am doing wrong ?
pix804
sadbulali Tue, 03/03/2009 - 19:40
To enable the PIX Firewall NTP client, enter the following command:
[no] ntp server ip_address [key number] source if_name [prefer]
To enable authentication for NTP messages, enter the following command:
[no] ntp authenticate
[no] ntp authentication-key number md5 value
[no] ntp trusted-key number
The ntp authenticate command enables NTP authentication. If you enter this command, the PIX Firewall will not synchronize to an NTP server unless the server is configured with one of the authentication keys specified using the ntp trusted-key command.
nlariguet Tue, 03/03/2009 - 20:19
and WHAT is the difference from what I posted:
ntp authenticate
ntp trusted-key 1
to what you're saying:
