02-25-2009 08:44 PM - edited 03-15-2019 04:29 PM
I have to integrate the call manager 4.2.1 with Cisco Catalyst 6509 switch (the Cisco Catalyst 6000 E1 VoIP Gateway)using MGCP
on the catalyst Switch, I have the voice module "WS-X6608-E1" ...
I am trying to search some document on how to do it... I can only find the document on how to configure the call manager on 4.2.1 .... but unable to locate document that can configure the catalyst 6509 voice module for MGCP... any idea where I can find it?
Solved! Go to Solution.
02-26-2009 10:07 PM
the config is just 1 line
set port voice interface 5/4 dhcp disable 192.168.100.214 255.255.255.0 vlan 100 tftp 192.168.4.40 gateway 192.168.100.1 dns 110.10.1.15
If using DHCP
#set port voice interface mod/port dhcp enable
# set port voice interface mod/port dhcp disable ip address subnet mask vlan <#> tftp ip address gateway ip address [dns ip address]
java
if this helps, please rate
02-26-2009 02:48 AM
Sure you can configure 6509 for MGCP
Your card will be placed in a module called CMM [ communication media module ]
and you'll deal then as you deal with any router in your configuration but first give your card a vlan to be able to interact with the backplane of your MLS so it can talk to your LAN
you can check this link for more details:
www.cisco.com/en/US/docs/net_mgmt/cisco_multicast_manager/2.4/user/guide/cmm_cf.html
Wish this be helpful
02-26-2009 03:14 AM
Be aware you can not do debugs on the 6509 for call tracing but have to use Dick Tracy - not very nice
02-26-2009 06:56 PM
I am a bit lost with this tool:CMM Administration Tool
is it something i have to down load and install?
normally i just telnet into the catalyst 6509 and using command line to configure other module...
is there any document that can guide me through how to configure MGCP on the E1 circuit via command prompt?
02-26-2009 10:07 PM
If using DHCP
java
02-26-2009 10:20 PM
Thanks heaps.
Kind regards
Rachel
