naveen_b81 Wed, 02/25/2009 - 23:42
I think the default port in cisco 2851 are routed ports and cannot perform switching. You can directly assign IP address to the two ports and connect them to the switchports in respective VLAN's.
Cheers,
Naveen
sameermunj Thu, 02/26/2009 - 00:18
Both ports should be in same subnet and should be part of all 4 vlans so if i enable dot1 q on that port i need to create 4 subinterfaces each on both the ports and assign ip addesses..somehow i want to bundle those 2 gig ports.
Paolo Bevilacqua Thu, 02/26/2009 - 01:16
  • Hall of Fame,
    Founding Member
You can use an IRB configuration to have both ports in the same subnet, that is, the same bridge group and configure L3 on the BVI interface.
However, one interface will block due to spanning-tree, and you will find that it's very unlikely that you ever experience faults in the connected switches, so actually there is much true redundancy to gain, at the cost of a more complicated configuration.
sameermunj Thu, 02/26/2009 - 01:30
so with IRB i will have 4 subinterafces on both gig ports corrosponding to 4 vlands and all 4 subinterfaces will be part of diffrent bridge group on both the gig port.so the configuration will look like
interface Gig 0/0
no ip address
interface Gig 0/0.1
encapsulation dot1Q 10
bridge-group 10
interface Gig 0/0.2
encapsulation dot1Q 20
bridge-group 20
interface Gig 0/0.3
encapsulation dot1Q 30
bridge-group 30
interface Gig 0/0.4
encapsulation dot1Q 40
bridge-group 40
interface Gig 0/1
no ip address
interface Gig 0/1.1
bridge-group 10
interface Gig 0/1.2
bridge-group 20
interface Gig 0/1.3
bridge-group 30
interface Gig 0/1.4
bridge-group 40
interface BVI 10
ip address 192.168.10.1/24
interface BVI 20
ip address 192.168.20.1/24
interface BVI 10
ip address 192.168.30.1/24
interface BVI 10
ip address 192.168.40.1/24
also it would be great if u can share with me the other solution which u feel complicated.
Paolo Bevilacqua Thu, 02/26/2009 - 01:38
  • Hall of Fame,
    Founding Member
Also configure "bridge irb" and "bridge 10 route ip".
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_tech_note09186a0080094663.shtml
Remember that only one port will be active at all times, so there is no bandwidth to gain.
If you're connecting to a single switch, you can use etherchannel instead, but consider that ISR routers do not have performances enough to fill one gigabit, so in that case too, it is not really worth it.
sameermunj Thu, 02/26/2009 - 02:08
i am connecting 2 diffrent switches so no chance to configure ether channel.
i dont mind 1 port in blocking mode as its 1 G port.
so in shorft i can have subinterfaces of the main interaface as part of diffrent brigde group.
u were talking about some other complicated configuration in previous mail.u have not highlited the same further.
Paolo Bevilacqua Thu, 02/26/2009 - 03:01
  • Hall of Fame,
    Founding Member
I meant the IRB config that is complicated and in many cases not necessary. If you have L3 switches configure inter-vlan routing there.
Remember to rate useful posts with the scrollbox below.
