CSA Agent Kits upgrade
Feb 25th, 2009
Hi all
I have a question. I have already made the migration from version 5.1 to 6.0, I would like to know how to upgrade Agent Kits? I need uninstall Agent Kit version 5.1 and download and install Agent Kit version 6.0 or there is a way for the migration Agent Kits?
Overall Rating: 5 (1 ratings)
tsteger1 Thu, 02/26/2009 - 11:30
You can schedule an upgrade for hosts under Systems>Software Updates>Scheduled Software Updates.
There is no need to uninstall first.
Tom
izavertaev Thu, 02/26/2009 - 19:49
thx for help :)
may I ask one more question?
when migration is done, the host are not attach to the group which i create. How I fix this? or I need attach again?
tsteger1 Thu, 02/26/2009 - 21:41
You can create an agent kit that automatically attaches them to the group you want them in and use that for the software upgrade or just move them manually.
Tom
