Voice gateway faileover is not working
Feb 26th, 2009
Contact Center setup :
1. ICM 7.2
2. CUCM 6.0
3. CVP 4.0
4. Voice gateway(Ingress & Vxml) - C3845 ver12.4
We have two Voice gateway. If primary voice gateway goes down, the secondary voice gateway should work as like primary.
Steps to describe the issue:
1. Primary voice gateway down
2. calls are hitting(terminating) the secondary voice gateway from PSTN.
3. Calls are not hitting the Scripts(ICM) and the IVR welcome message is not playing. i.e it is also not invoking the vxml application to play the welcome message.
Appreciate your suggestion..
Assume you have set the label on the NVRU for the CVP RC to "8111111111" then further assume you have also added to the CVP Call Server config (assuming SIP) the pattern "8111111111>" to the Send To Originator section. Is this true?
If so, you are not relying on any static routes in either CVP or the Proxy to direct the VRU leg.
All I can say is upload the two router configs to your PC and run an visual diff tool on them. These should be almost identical.
Is the ICM script failing in the "Send To VRU" node?
Geoff
That's not what I asked at all. What I asked was "is it failing in the Send to VRU node"?
If it's not even triggering the script for the DN being sent up from the gateway, then one of two things are wrong. (a) your dial peers are wrong or (b) the carrier is sending up a different DNIS on those PRIs.
Run debug isdn q931 on gateway 2 to eliminate (b). Run debug voice dialpeer inout to check (a).
Geoff
Pandiyan.d Thu, 02/26/2009 - 04:32
you mean send to VRU node at scripts if so the call not at all reaching the send to VRU node at scripts.and script as well
But i got an DN at gateway when i run the debug isdn q931
This is my secondary gateway voice config..please check it
dial-peer voice 101 voip
description NewYork-Primary VXML Gateway to Gurgaon-Primary Callserver
translation-profile incoming block
preference 1
destination-pattern 8.........
session protocol sipv2
session target ipv4:10.10.10.60
dtmf-relay rtp-nte h245-signal h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 102 voip
description NewYork-Primary VXML Gateway to Gurgaon-Secondary Callserver translation-profile incoming block
preference 2
session target ipv4:10.10.10.61
codec g711ulaw
no vad
