RTR configuration commands not showing in running config
Feb 26th, 2009
We have rtr configured on some of our 3660 and 2600 routers, when you do a show rtr config it displays the config output. However, there is no actual rtr configuration in the running/startup config, no command lines relating to rtr whatsoever. The IOS versions are 12.2(29) and 12.3(13a). Is this normal?
pkurdziel Mon, 03/30/2009 - 19:13
It sounds like you have logged in with an account with limited privileges.
