02-26-2009 04:51 AM - edited 03-06-2019 04:16 AM
I have 12 * 1242 AP's hanging off of a 12 port 3560. Is the 12 port 3560 able to support 12 Class 6 POE devices.
It seems to be denying power as you can see from the debugs attached.
Eoin.
02-26-2009 05:44 AM
I would check to see if the 3560's will support class 6 , I'm not sure they will support any more than class 5 devices per port .
02-26-2009 07:09 AM
Hello Eoin,
Have you enable PoE on the port or is it in Auto?
DAK
02-26-2009 07:31 AM
No, you need to 3560-E model.
HTH,
__
Edison.
