ohassairi Thu, 02/26/2009 - 06:11
if you have a ciscoworks machine this could be easy.
i imagine you don't have it.
1-first determine the mac address of your computer .
2-then choose one switch that has PCs in same vlan, telnet to it and issue the command
switch# sho mac-address-table | inc yourmacaddress
if the PC is connected to that switch then you will get directly the port.
if not the switch will indicate to you an uplink to a second switch
repeat same steps with second switch
Anonymous (not verified) Thu, 02/26/2009 - 06:13
The device I'm trying to find is a printer so I'm not able to telenet into it.
Tshi M Thu, 02/26/2009 - 06:21
sh ip arp x.x.x.x.
this will return the MAC address belonging to the IP
once you have the mac address, you use
sh mac-add | i xxxx.xxxx.xxxx
below is an example
3560-sw1#sh ip arp 10.64.155.62
Protocol Address Age (min) Hardware Addr Type Interface
Internet 10.64.155.62 21 0011.43b4.7f0f ARPA Vlan101
3560-sw1#sh mac-add | i 0011.43b4.7f0f
101 0011.43b4.7f0f DYNAMIC Gi0/32
Anonymous (not verified) Thu, 02/26/2009 - 07:30
I would already have to know which switch the printer is attached to in order for that to work - correct?
Tshi M Thu, 02/26/2009 - 07:37
No you don't need to know the switch where the printer is connected to. You can use the sh ip arp x.x.x.x from any switch. Once the mac address is found, you can work your way up to where the device is connected. the sh mac-add | i xxxx.xxxx.xxxx might point to an uplink. You will then go to that switch and work your way to the right switch.
Anonymous (not verified) Thu, 02/26/2009 - 07:31
Mohamad Qayoom Thu, 02/26/2009 - 07:36
No, you can go to the core and do the following:
ping x.x.x.x
sh ip arp x.x.x.x
Now you will see MAC address aaaa.bbbb.cccc
sh mac-add add aaaa.bbbb.cccc
Here you will see port-channel or uplink port. Now see what switch is connected through that port-channel onr uplink.
Go to that switch and do
ping x.x.x.x
sh ip arp x.x.x.x
