NEED INFORMATION REGARDING MIB
Feb 26th, 2009
what is MIB , what is the use of MIB in LMS.what are the MIB values for cisco devices.where we upload these MIB values.
what is the significance.
also what is system object identifier or OID.
AND WHAT IS THE USE OF SNMP WALK.
Vaibhav
akemp@powertel.com Thu, 02/26/2009 - 06:18
  • Silver, 250 points or more
1. A MIB is Management Information Base, a description of managed objects written in ASN1 notation.
2. Not much, a little in DFM, but most of the OIDs are "hidden behind the curtains" so to speak.
3. You install device "packages" in Commons Services.
MIB stands for Management Information Base and is a collection of information organized hierarchically. These are accessed using a protocol such as SNMP. There are two types of MIBs: scalar and tabular. Scalar objects define a single object instance whereas tabular objects define multiple related object instances grouped in MIB tables.
OIDs or Object Identifiers uniquely identify manged objects in a MIB hierarchy. This can be depicted as a tree, the levels of which are assigned by different organizations. Top level
MIB object IDs (OIDs) belong to different standard organizations. Vendors define private branches including managed objects for their own products.
What is the significance of these things ? They describe how information about a device's configuration, operation and errors that's running a SNMP agent can be accessed remotely using the SNMP protocol.
SNMP WALK allows you to query a SNMP agent to navigate down the hierarchy from the most general to the most specific granular information values on a remote device.
vaibhav-g Thu, 02/26/2009 - 21:06
Hi Thanks
could you elaborate the SNMP WALK with any example. their is any link to see MIB's for the devices.
vaibhav
vaibhav-g Fri, 02/27/2009 - 09:46
i want to know where we put OID values in LMS in which module and what is the use.
same for MIB values where we put in LMS.what is the use of MIB.
where can i get MIB values.
Vaibhav
vaibhav-g Mon, 03/02/2009 - 08:53
HI.
could you reply on the above query also.
Regrds
Vaibhav
vaibhav-g Wed, 03/04/2009 - 11:10
could you provide the OID value for clean access manager 3310.
Vaibhav
