ASA SSL VPN Customisation problem
I'm doing some customisations on the Portal page, its a Clientless SSL access profile.
Having created some nice bookmarks etc I want to create a "Custom Pane" in the Portal customisation tool, so that I can show a view of an internal Intranet site in the portal page beneath my bookmarks.
Problem is, when I connect into the portal I find that once the custom pane displays (in the portal), the browser session gets redirected to that intranet site. The portal toolbar appears as normal, I can click home to go back to the portal but it immediately redirects again to the site in the custom pane.
I've tested a few Intranet sites and it does not happen in every case. But the behavior is happening on the Corporate intranet site which is the one I'd like to show off !!
The site in question is running on a Lotus Notes Web server.
The ASA 5520 is running latest code (8.04) and asdm 6.1(5)51.
Neil.
