02-26-2009 06:53 AM - edited 03-14-2019 03:44 AM
Using IPCC Ent 7.X with CVP. In an ICM script we have a set variable node with the formula,
"CSCloseTime=",Call.Peripheral9
I am trying to figure out where this Call.Peripheral9 value is being set. I understand that it is a standard ICM Peripheral Variable but do not set this value being set in the script, in any admin script, or in Configuration Manager. Just looking for guidance here. Where else do I need to look?
Solved! Go to Solution.
02-26-2009 07:14 AM
Oh, now I see what you mean. I would double check your admin scripts, the variable sounds like a schedule variable.
david
02-26-2009 06:56 AM
Correction:
It is:
"CSCloseTime=", Call.PeripheralVariable9
02-26-2009 07:07 AM
It can be done in an admin script or routing script.
Use the Set Node. Top of the set node will point to PV9. Bottom of the set node the value you want to set it to like ("cat").
david
02-26-2009 07:09 AM
Thanks for the reply. I understand what you have said but do not see this variable being set in any routing or admin script.
02-26-2009 07:14 AM
david
02-26-2009 07:17 AM
That is what I was thinking but can't find it. I will check again. Thanks.
02-26-2009 07:34 AM
Got it! Found it in a routing script that was calling for that value from the CVP box.
