Intercom for CME
Feb 26th, 2009
I have to hook up our CME to an interfom. I am assuming i need fxo ports and a dial plan that sends calls to that fxo port. Then into the intercom.. Is this theory correcT?
rob.huffman Thu, 02/26/2009 - 07:49
Hi Mike,
This is indeed the correct theory :) Just check the maufacturers specs to determine if an FXS (where you just dial up a station DN) should be used over FXO. This is a good thread that discusses these thoughts;
Hope this helps!
