IKE Error when using VPN client
admin_2
Level 3
Level 3
Can any tell me what might be causing the following error when i connect to my ASA using a CISCO VPN client.
3 Feb 26 2009 15:16:18 713042 IKE Initiator unable to find policy: Intf INSIDE, Src: x.x.x.x, Dst: x.x.x.x
11 Replies 11
Ivan Martinon
Level 7
Level 7
This happens when traffic from inside to outside is trying to match a vpn connection that does not have a defined policy, usually when the dynamic crypto map is defined before the statics or if there is a match address on the dynamic map. Can you post your config?
auraza
Please check if you have the "crypto isakmp enable INSIDE" command on the ASA, as you seem to be connecting to the INSIDE interface.
Not applicable
Not applicable
Not applicable
Not applicable
Not applicable
