stuck in oracle at imaging
Feb 26th, 2009
Hi everybody,
I'm imaging a 100E with 6.0.2.
When I do a reboot the initial startup gets stuck at "starting oracle:".
Is this a known issue?
Can someone help me with this problem
mdreelan Thu, 02/26/2009 - 08:12
yes, this just take a while to boot. I have seen it take as long as 90 minutes. Also, if the device fails to perform normall after the ISO upgrade, try making a new DVD on a different PC and start over. I just wnet through this on a CSMARS-50
pcoates84 Mon, 07/06/2009 - 11:53
I've encountered a similar issue with a 110R.
I had to re-image the box, first had the Oracle Fail with the 6.0.2 DVD I burned, so I used the recovery DVD included with the device, this was successful, however "Starting Oracle" is taking way too long, I let it sit for over 2 hours, the activity light and HD lights flash occassionaly, but it's much too long, I'm restoring again from the included disk, and then will try another Downloaded DVD, but will burn at a slow speed this time.
Anyone else experience similar issues?
