WCS License
Feb 26th, 2009
Hi to all,
some question about WCS license
1) I have to upgrade fram base to loc license need i a particular wcs release or can i to continue to use 4.2
2) I can't find a procedure to upgrade the license....is it just to load a license for the first time
3) what happne If i
ve a 100 Ap license and i add one more AP
thx........
andrew-mccabe Thu, 03/05/2009 - 05:52
As far as I understand it, you need to support more access points than your current licence supports. If this is the case then all you need to do is buy another licence and add it and it will work with your existing one. I have just done the same thing.
Trending Topics - Security & Network
