IP SLA: ICPIF always 1, MOS always 4.34
Feb 26th, 2009
Hi there
Last week, a regional branch encountered echo in the Voice-Service and our VoIP-Provider saw a Problem with Jitter.
Amongst other things, we decided to monitor Jitter with IP SLA.
RTR-Responder: Catalyst 3560G with c3560-ipservicesk9-mz.122-25.SEE2
Sender: set up on a Catalyst 3560G with c3560-ipservicesk9-mz.122-46.SE
conf on sender:
ip sla 3
udp-jitter 10.144.202.16 32514 codec g711alaw
tos 46
frequency 30
ip sla schedule 3 life forever start-time now
this results to:
n91250-0280#sh ip sla conf 3
IP SLAs, Infrastructure Engine-II.
Entry number: 3
Owner:
Tag:
Type of operation to perform: udp-jitter
Target address/Source address: X.X.X.X/0.0.0.0
Target port/Source port: 32514/0
Type Of Service parameter: 0x2E
Operation timeout (milliseconds): 5000
Codec Type: g711alaw
Codec Number Of Packets: 1000
Codec Packet Size: 172
Codec Interval (milliseconds): 20
Advantage Factor: 0
Verify data: No
Vrf Name:
Control Packets: enabled
Schedule:
Operation frequency (seconds): 30
Next Scheduled Start Time: Start Time already passed
Group Scheduled : FALSE
Randomly Scheduled : FALSE
Life (seconds): Forever
Entry Ageout (seconds): never
Recurring (Starting Everyday): FALSE
Status of entry (SNMP RowStatus): Active
Threshold (milliseconds): 5000
Distribution Statistics:
Number of statistic hours kept: 2
Number of statistic distribution buckets kept: 1
Statistic distribution interval (milliseconds): 20
Enhanced History:
Now, the special thing are the results:
n91250-0280#sh ip sla stat agg 3
Round Trip Time (RTT) for Index 3
Start Time Index: 16:22:48.637 MET Thu Feb 26 2009
Type of operation: jitter
Voice Scores:
MinOfICPIF: 1 MaxOfICPIF: 1 MinOfMOS: 4.34 MaxOfMOS: 4.34
RTT Values
Number Of RTT: 65809
RTT Min/Avg/Max: 4/9/455 ms
Latency one-way time milliseconds
Number of Latency one-way Samples: 27487
Source to Destination Latency one way Min/Avg/Max: 0/3/288 ms
Destination to Source Latency one way Min/Avg/Max: 6/9/454 ms
Jitter time milliseconds
Number of SD Jitter Samples: 65741
Number of DS Jitter Samples: 65741
Source to Destination Jitter Min/Avg/Max: 0/2/277 ms
Destination to Source Jitter Min/Avg/Max: 0/3/414 ms
Packet Loss Values
Loss Source to Destination: 0 Loss Destination to Source: 0
Out Of Sequence: 0 Tail Drop: 2191 Packet Late Arrival: 0
Number of successes: 68
Number of failures: 0
Quite ugly Jitter-Times, but great values for ICPIF and MOS, without any variation. Of course I reported only the latter to management and dissed the guys from the branch office :)
joking apart: what went wrong with those values? did we miss something in the configuration, is this a bug or is a cat3560 simply not able to compute ICPIF or MOS?
On a side node: Is there any good guide, how to interpret IP SLA Jitter Values like what values in "Destination to Source negative jitter Number/Sum/Sum2" would be good/reasonable/catastrophic?
thx in advance and greetings from bern
stefan mueller
