Show color jpg image on 7970
Answered Question
Feb 26th, 2009
Hi to all,
I'm sorry, I'm not a developer, but I need to resolve this issue.
I have to show a color JPG image provided by a IP network camera to FTP share (Axis), I already have CiscoIPservices installed on a IIS server and it works.
My problem is that I'm not be able to show a color img on 7970 (or 7920) phone!
Somebody know if it is possible or better do you have any example already did? I seen a application like that in a Cisco Lab.
Thank you very much!
Augusto.
Correct Answer by msabir about 8 years 3 months ago
You will need to convert images to PNG format, and resize them. You will need to use CiscoIPPhoneImageFile object or if you want to use touch screen enabled image, use CiscoIPPhoneGraphicFileMenu:
Image Title goes here
Prompt text goes here
Horizontal position of graphic
Vertical position of graphic
Points to the PNG image
Overall Rating: 5 (1 ratings)
paolo bevilacqua Thu, 02/26/2009 - 13:56
  • Hall of Fame,
    Founding Member
Augusto, you need a programmer to download the phone sdk (free). From there you begin customizing or writing you own application.
Correct Answer
msabir Fri, 02/27/2009 - 06:42
  • Bronze, 100 points or more
