Meetme enter/exit tone
Answered Question
Feb 26th, 2009
Is there a way to set a different exit tone when a caller hangs up from a meetme conference than the enter tone when someone connects to a meetme conference.
By default it is the same tone when someone connects to the meetme as when they disconnect. This seems to be confusing to some users and I would like to change it if possible.
Thanks.
Correct Answer by Jaime Valencia about 7 years 12 months ago
unfortunately it's not possible, the tone is generated and is the same one. the system refers to the same tone and cannot be changed one for new comers and one for guys logging out
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 02/26/2009 - 08:49
java
