ASA redistribution using route-map
Feb 26th, 2009
I'm trying to accomplish redistribution between two ospf processes using a route-map with an access-list on an ASA.
Can't seem to get it working. Does anyone know if this is possible or if i have something messed up? See below:
redistribute ospf 175 metric-type 1 subnets tag 10457 route-map OSPF175-OSPF100-RMAP
route-map OSPF175-OSPF100-RMAP permit 10
match ip address OSPF175-OSPF100-ACL
access-list OSPF175-OSPF100-ACL remark Used for redistribution
access-list OSPF175-OSPF100-ACL standard permit host x.y.z.0
access-list OSPF175-OSPF100-ACL standard permit host 0.0.0.0
Thank you,
Tom
adamclarkuk_2 Thu, 02/26/2009 - 14:35
  • Silver, 250 points or more
Hi Tom
This worked for me, here is my setup
FW0---->(OSPF process 1)FW1(OSPF process 2)---->FW2
FW0 is passing a /32 (192.168.10.1) via OSPF to FW1 process 1 who then redistributes into OSPF process 2 and passes the route onto FW2.
FW1 Config
route-map eigrp_redis permit 10
match ip address eigrp_redist
access-list eigrp_redist standard permit host 192.168.10.1
router ospf 1
network 192.168.1.0 255.255.255.252 area 0
log-adj-changes
router ospf 2
network 192.168.2.0 255.255.255.252 area 0
log-adj-changes
redistribute ospf 1 metric-type 1 subnets tag 10457 route-map eigrp_redis
Routing table for FW1
O E1 192.168.10.1 255.255.255.255 [110/11] via 192.168.1.1, 0:04:28, inside
C 192.168.1.0 255.255.255.252 is directly connected, inside
C 192.168.2.0 255.255.255.252 is directly connected, ouside
Routing table for FW2
O E1 192.168.10.1 255.255.255.255 [110/21] via 192.168.2.2, 0:01:34, inside
C 192.168.2.0 255.255.255.252 is directly connected, inside
I am running code 7.2
FW1# sh ver
Cisco PIX Security Appliance Software Version 7.2(2)19
How are your /32 routes begin learned at the point of redistribution ?
