PIX split tunnel
I'm implemented a split tunnel (thanks to several posts here) and it works great. But now it seems I've lost the ability to use a static route I have defined (see below). With the split tunnel enabled I am no longer able to get to the devices on the other side of when connected via vpn.
route inside xx.xx.xx.0 1
auraza Thu, 02/26/2009 - 12:29
What is your split-tunnel acl? What networks are you trying to reach? Do they have a route back to the VPN Pool that you are assigning to your clients?
auraza Thu, 02/26/2009 - 12:45
Your split-tunnel ACL works better if it is a standard acl, so suppose you need to get to the network, your split-tunnel acl should be:
access-list split_tunnel standard permit
Add networks to this ACL as needed.
