Warning message
CME Not allowing User to enter Pin Codes\passwords
Feb 26th, 2009
We have a customer who is running a CME system with a SIP trunk to a certain provider.
When The user calls into a conference bridge they connect. The conference bridge requests the to enter their meeting ID\passcode etc. They are having to re-enter several times before it takes. I'm lost on this one, anyone heard of anything like that?
testeven Thu, 02/26/2009 - 16:18
  • Cisco Employee,
Hi!
Sounds like a DTMF issue. What type of DTMF relay is the provider expecting or using?
There was a similar issue when using 'dtmf-relay sip-notify' instead of 'dtmf-relay rtp-nte'
You can collect the following debugs:
debug voip rtp session dtmf-relay
debug voip rtp session named-evet
Hope this helps!
Teresa.
Nicholas Matthews Thu, 02/26/2009 - 18:11
  • Red, 2250 points or more
Hi Clint,
I'll put my bets on this bug: CSCsv04751
It's something I filed a month or two back and we've seen a lot of activity on it.
You can test this by making a call with the handset and pressing the DTMF digits for a bit longer than normal. Then, try it with the speaker phone. I suggest trying something like the TAC hotline option 2, where it will repeat the digits back to you. You're probably getting duplicate DTMF.
This bug happens on phones loads 8.4.1 and 8.4.1 SR1. It's fixed in 8.4.1 SR 1 and later (8.4.2, 8.4.3, etc).
hth,
nick
